Missing "Deforming domain"
I am trying to follow the "Vibrating Beam in Fluid Flow" example. (https://www.comsol.com/model/download/483481/models.sme.oscillating_fsi.pdf).
There is a step "DEFINITIONS Deforming Domain 1 1 In the Model Builder window, under Component 1 (comp1)>Definitions click Deforming Domain 1. 2 Select Domain 1 only. 3 In the Settings window for Deforming Domain, locate the Smoothing section. 4 From the Mesh smoothing type list, choose Yeoh."
However, I could not fin the Deforming Domain 1. I followed all the steps above this one, and I got stacked here.
Could someone help me with this issue and tell me where can I find the "Deforming Domain 1"?
Thank you very much.
1 Reply Last Post 2018/04/03 6:54 GMT-4
Posted: 8 years ago 2018/04/03 6:54 GMT-4
Hi Renyun,
Please check that the step-by-step instructions you are using matches the program version. If you are running a version earlier than 5.3a, but use the instructions for 5.3a, then this would happen.
Henrik
Henrik Sönnerlind
COMSOL
Hi Renyun, Please check that the step-by-step instructions you are using matches the program version. If you are running a version earlier than 5.3a, but use the instructions for 5.3a, then this would happen. Regards, Henrik
