Increment of Variable/Argument name used in Function
Posted 2011/04/27 14:14 GMT-4 Interfacing, Parameters, Variables, & Functions Version 4.1 3 Replies
I'm trying to increment variable name in a command:
___________________
ie: model.geom('geom1').feature.create('b1', 'BezierPolygon');
Here I'll like to increment 'b1' each time loop is passing over this command (considering the command into a if loop per example)
____________________
Usually, I use evalc to increment matrix name in Matlab:
for i=1:10
evalc(['b' num2str(i) '=zeros(N,N)'])
end
Here it doesn't work, since Matlat interpret this as an undefined variable (since I do not assign anything to the variable)
I'm sur it is not complicated !
Any help would be appreciated.
___________________
for i=1:10
end
3 Replies Last Post 2011/04/28 20:48 GMT-4
