Edgar J. Kaiser
        Certified Consultant
                                8 years ago
                                2018/04/12 15:35 GMT-4
                                                    Peter,
Sure you can. The magnetic flux density components are complex quantities.
Cheers
Edgar
    Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
                            Peter,
Cheers
Edgar
                                8 years ago
                                2018/04/12 17:06 GMT-4
                        Updated:
                                8 years ago
                                2018/04/12 17:35 GMT-4
                                                    Ok, based on your comment I'm seeing that I need to activate the "Split complex variables in real and imaginary parts" check box in the "Compile Equations: Stationary" and then plot expressions like real(mf.normB) and imag(mf.normB) to access the complex values, etc. to get explicit phase information. Can you confirm this is the correct approach?
CORRECTION: I suppose I'll want to plot real(mf.Bx) imag(mf.Bx) etc.
Thank you for your advice.
-Peter
-Peter
                                Edgar J. Kaiser
                                8 years ago
                                2018/04/12 17:47 GMT-4
                                                    You don't need to split the complex variables. The real() and imag() operator extracts the components.
    Edgar J. Kaiser
www.emphys.com
                                8 years ago
                                2018/04/12 17:52 GMT-4
                                                    Oh ok. Thanks! Applying this to an application model now and getting somewhere...
I appreciate it.
I appreciate it.
