Coupled Electro-thermal model (Using variable from one study step as input to another study step
Posted 2018/05/16 9:57 GMT-4 Low-Frequency Electromagnetics, Parameters, Variables, & Functions, Studies & Solvers 0 Replies
Hello all,
I am doing a coupled electro-thermal model in comsol. I solve the magnetic field with a stationary solver and the thermal with time-dependent. The coupling is some sort of weak coupling. In the variables, I define a variable X which is a function of normH. I solve magnetic field. I have the solution. When I plot normB and X, both looks reasonable. Now I use the variable X as an input boundary heat source in the 'heat transfer in solids' physics and solve the time-dependent. The solution converge but the result is equivalent to considering the boundary heat source = 0, meaning that the value of X is not taken into account.
I also tried to use the solution of the stationary as 'variables that are not solved for', in the time dependent solver, but the solution fails with an error: inconsistent initial values.
Is there any way to uses the variable calculated from the one solution to use as an input to the other solver?
Hello Bishal Silwal
