Edgar J. Kaiser
        Certified Consultant
                                7 years ago
                                2018/05/28 11:30 GMT-4
a nonlinear approach using a BH curve is no problem. This holds for static and time dependent models.
Cheers
Edgar
    Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Cheers
Edgar
                                7 years ago
                                2018/05/28 11:43 GMT-4
                        Updated:
                                7 years ago
                                                    Hello Edgar,
Thank you for the rapid reply,
I do have some B-H curves, however the issue is not getting the H field first, and from the B-H curve the deduction is straight forward.
Maybe I wasn't clear in my previous post (or even misleading ) but the issue in these cases is the H field inside the material, since the tangential component is continuous , however we egnore the normal component.
I was wondering if there is a solution in COMSOL that uses something else other then LLG model.
                            Hello Edgar,
                                Edgar J. Kaiser
                                7 years ago
                                2018/05/28 13:04 GMT-4
                                                    Sorry, I don't get what the issue is.
    Edgar J. Kaiser
www.emphys.com
                                7 years ago
                                2018/05/29 4:22 GMT-4
                        Updated:
                                7 years ago
                                2018/05/29 4:24 GMT-4
                                                    Hello Edgar,
It isn't possible to use the B-H curve if one doesn't know the H field inside the material.
The B-H field is a obtained in the case where we know the H field inside the material, and this by making its direction tangential to the surface of the material and its value uniform along the specimen, in the attached picture I try to explain that.
The use of "closed" specimen forms, helps us avoid the discotinuity of the normal component of the H field at the boundaries.
The B-H curve becomes usuful when one knows the H field inside the material.
Once again I thank you for your rapid replys, and I hope COMSOL can provide what we are looking for (The magnetic field density H inside a ferromagnetic material)
Best regards
                            Hello Edgar,
*The use of "closed" specimen forms, helps us avoid the discotinuity of the normal component of the H field at the boundaries.*
Best regards
                                Edgar J. Kaiser
                                7 years ago
                                2018/05/29 9:06 GMT-4
                                                    Comsol solves for the magnetic scalar potential Vm or the magnetic vector potential A and the nonlinear material model is respected by the solver. The magnetic field H is made available as the gradient of Vm or the curl of A.
    Edgar J. Kaiser
www.emphys.com
