Pumping fluid by external loading
Posted 2018/06/14 15:03 GMT-4 Computational Fluid Dynamics (CFD), Microfluidics, Particle Tracing for Fluid Flow Version 5.3 0 Replies
Hello, I am modeling a pipe which is very flexible, a displacement is applied on a strip of the walls (to pump the fluid). If the two ends of the pipe are connected to the same tank, and the whole tube is inundated in liquid. What should be the boundary condition I should use at the inlet and exit of the tube? I am modeling it as a axisymmetry 2D problem. Thanks
Hello Mohamed Ibrahim
