Submodeling
Posted 2018/06/19 20:43 GMT-4 Porous Media Flow, Optimization, Structural Mechanics Version 5.3a 4 Replies
Hello:
I am trying to carry out submodeling using "General Extrusion" operator. I was wondering if it is necessary to cut the the critical part out from the global model to perform submodeling?
I am working on a problem in which the global model has only three domains. My submodel is a cylinder (one of the domains in the global model). I created this cylinder in the submodel (not cut out from the global model) (with same dimensions and material properties as in the global model) and used "General extrusion operator" to transfer results from global model to submodel.
I was wondering if this approach is correct as I did not "cut" this cylinder from the global model?
While defining the "General Extrusion operator", I was wondering if I need to select all the three domains of the global model as the source or should I only select the cylinder as the source as I did not performed any cut in the global model?
I look forward to hearing your comments.
Thanks, Shashank
