Confusing Error Message
Posted 2018/07/12 20:15 GMT-4 Electromagnetics, Low-Frequency Electromagnetics, Studies & Solvers Version 5.3 2 Replies
Hi All,
I've been working for a bit on a model of a detector using the mf interface from the AC/DC module, but have realized that I muight reformulate the problem using the mef interface (mf doesn't connect to a circuit how I want). I've set up the model the same way for the mef version as I did for mf, and am trying to run it in both stationary and frequency domain studies. However, I get the following error message:
- Feature: Stationary Solver 1 (sol2/s1) Failed to find a solution. The relative residual (1.1e+011) is greater than the relative tolerance. There was a warning message from the linear solver. Iterative refinement triggered. Returned solution is not converged.
I've attached the model below and was hoping someone could explain how to fix this. It's a pretty simple problem that can be done with pencil and paper, so I suspect that I'm missing some simple technical detail about COMSOL that I haven't found in my online searches so far.
Thanks, Henry
