Hello Muhammad Assad
2011/11/26 4:44 GMT-5
Dear colleague,
Did you solve the problem? In case you did, please send the improved model.
Regards
Dear colleague,
Regards
2013/02/09 7:22 GMT-5
Did you get the improved model?
If YES, can i have it too?
2014/08/28 12:28 GMT-4
There are multiple syntax errors (missing * sign, m63 instead m^3) or maybe they've appeared when i opened the file with comsol 4.3
Also, you have circular dependency: rhoss depends on Qm wich depends on phoss
You'll need to solve equation of hydrogen concentration (chemical reaction's rate equation). Look at appropriate articles, for example, M. GAMBINI, METAL HYDRIDE ENERGY SYSTEMS PERFORMANCE EVALUATION. PART A: DYNAMIC ANALYSIS MODEL OF HEAT AND MASS TRANSFER
I'm currently working on almost same case, but it keep giving me an error "trying to find logarithm of negative number" while the expression is log(abs(p)) !...
2014/09/16 16:48 GMT-4
I did something to the file and tried to improve it.
The main problem is in the heat source equation and inconsistent units.
If you wish we can work that together.
I am also trying to so that using FlexPDE software.
2014/10/10 9:53 GMT-4
If interested I can send you the file by e-mail.
2015/01/14 6:47 GMT-5
yes, please send me files.
2015/01/15 7:05 GMT-5
Try out with some constant values...may be you will get results..i am also hydrogen storage models..till now my results are not satisfactory....
2015/03/29 14:51 GMT-4
what is your e-mail?
2015/03/30 8:39 GMT-4
e-mail adress: ihilali@gmail.com
2015/04/21 3:31 GMT-4
I used comsol for the same problem, can you please send me the model?
Many thanks.
Many thanks.
2015/04/21 3:38 GMT-4
I downlod your model and i think there is a lot of thing miss in your model.
me i used the PDE for hydrogen absorption rate.
my problem is just related with initial and bondary conditions.
if you want, we can work together.
2015/04/21 5:33 GMT-4
2015/05/28 14:54 GMT-4
What is your e-mail? Mine is jehadyam@yahoo.com
9 years ago
2016/05/27 15:48 GMT-4
Did you solve your problem with the metal hydride model?
