Studying deformation in a porous structure (Brinkman equation)
i am working on studying stress and deformation in porous media as fluid flows through it ... i tried using solid mechanics, but it considers the porous structure as impenetrable solid. And if i use proroelasticity, it uses Darcy's law, but the flow inside the porous structure is governed by Brinkman eqaution. Is there a way around this problem?
- JD
1 Reply Last Post 2015/03/09 12:08 JST
Hello Carrie German
Posted: 1 decade ago 2015/03/09 12:08 JST
Hi JD,
Did you ever find a solution to this?
Thanks!
Andre
Hi JD, Did you ever find a solution to this? Thanks! Andre
