deformation of ceramics
my problem is: The material I want to use is ceramics, which is very stiff and has a much smaller deformation than the computation shows.
If I choose the ceramics from the Material Libary I get the same (wrong) results.
Thank you for your help
1 Reply Last Post 2011/05/24 23:13 JST
Posted: 1 decade ago 2011/05/24 23:13 JST
are you sure you are respecting the units overall in your model ? that you are not loading in [N] instead of [Pa] or something like that (or that you are in "m" and not "mm", or the opposite ...), these things are easily overlooked.
For me so far, once such small typos corrected, have given me coherent results over the last years, so I rather trust COMSOL ;)
Hi are you sure you are respecting the units overall in your model ? that you are not loading in [N] instead of [Pa] or something like that (or that you are in "m" and not "mm", or the opposite ...), these things are easily overlooked. For me so far, once such small typos corrected, have given me coherent results over the last years, so I rather trust COMSOL ;) -- Good luck Ivar
