Error "Attempt to evaluate negative power of zero"
The error is as follows:
Attempt to evaluate negative power of zero.
- Function: ^
- Expression: d(d((-(mod1.fct-(Tm-mod1.T)*switch(t/unit_s_cf)*mod1.fc^(2/3)/unit_K_cf)*test(mod1.fc))*(dvol),{test@2}),mod1.fc)
In the expression, the only place that contain the function ^ is fc^(2/3). In the model, the fc can be zero, but why the error is "Attempt to evaluate negative power of zero." ? The power is 2/3, why comsol treat it as negative?
13 Replies Last Post 2016/12/17 1:39 JST
Posted: 1 decade ago 2011/06/21 20:33 JST
i meet the same error when dealing with a discontinuse function
Posted: 1 decade ago 2011/07/27 13:21 JST
I have the same problem.
I think COMSOL wants to derive this equation. If you derive x^(2/3) the results is (2/3)x^(-1/3) so there is a negative power.
I don't find a way to solve this problem, if you succeed can you say me how you did please?
Alexis
I have the same problem. I think COMSOL wants to derive this equation. If you derive x^(2/3) the results is (2/3)x^(-1/3) so there is a negative power. I don't find a way to solve this problem, if you succeed can you say me how you did please? Alexis
Michael Rembe Certified Consultant
Posted: 1 decade ago 2011/07/27 15:48 JST
May be there is an expression that becomes negative. Check your expressions!
In some cases there are expressions that should be zero. But because of numerical effects they get a very small negative value. That may cause this error. In this cases you can add 'eps', a very small number, to your expression. May be, it helps.
Michael
May be there is an expression that becomes negative. Check your expressions! In some cases there are expressions that should be zero. But because of numerical effects they get a very small negative value. That may cause this error. In this cases you can add 'eps', a very small number, to your expression. May be, it helps. Michael
Posted: 1 decade ago 2011/07/27 20:02 JST
I always had this error, when the initial values (start field) where too far off from the solution. It had nothing to do with the expression being zero, as I had added a small value to stop it from becoming zero. I managed to avoid this error by first solving a simpler problem (without the power 2/3 maybe?) and then using the solution as the start field.
Hope this helps,
Nina
Hi, I always had this error, when the initial values (start field) where too far off from the solution. It had nothing to do with the expression being zero, as I had added a small value to stop it from becoming zero. I managed to avoid this error by first solving a simpler problem (without the power 2/3 maybe?) and then using the solution as the start field. Hope this helps, Nina
Posted: 1 decade ago 2011/07/27 21:35 JST
Alexis
Your are right. In my model, the initial value of fc is zero, so I just plus an very small number eps, and it worked.
[QUOTE] I have the same problem. I think COMSOL wants to derive this equation. If you derive x^(2/3) the results is (2/3)x^(-1/3) so there is a negative power. I don't find a way to solve this problem, if you succeed can you say me how you did please? Alexis [/QUOTE] Your are right. In my model, the initial value of fc is zero, so I just plus an very small number eps, and it worked.
Posted: 1 decade ago 2011/07/28 11:03 JST
I want to create a plastic law : k*(solid.epe^n) where k,n are constants and solid.epe is the plastic strain.
I have tried with k*((solid.epe+eps)^n), the model computes but when I want to analyse the stress I have the same error message!
Have you any idea?
Alexis
I want to create a plastic law : k*(solid.epe^n) where k,n are constants and solid.epe is the plastic strain. I have tried with k*((solid.epe+eps)^n), the model computes but when I want to analyse the stress I have the same error message! Have you any idea? Alexis
Posted: 1 decade ago 2011/07/28 22:12 JST
Have you any idea?
Alexis
I don't know much about your model. You said your model can run, but during the postprocessing, the error occurred. What's the expression of the stress?
[QUOTE] I want to create a plastic law : k*(solid.epe^n) where k,n are constants and solid.epe is the plastic strain. I have tried with k*((solid.epe+eps)^n), the model computes but when I want to analyse the stress I have the same error message! Have you any idea? Alexis [/QUOTE] I don't know much about your model. You said your model can run, but during the postprocessing, the error occurred. What's the expression of the stress?
Posted: 1 decade ago 2011/08/10 9:37 JST
Thanks for your answer, I have succeed to create my plastic law by studying the COMSOL model: elastoplastic_plate.
Cheers,
Alexis
Thanks for your answer, I have succeed to create my plastic law by studying the COMSOL model: elastoplastic_plate. Cheers, Alexis
Posted: 1 decade ago 2011/09/18 16:24 JST
Hello everyone,
I had the same problem, you can see my problem:
Function: ^
Expression: d(d((up(mod1.nitf.rho)*up(mod1.nitf.Cp)*mod1.nitf.C mu^0.25*sqrt(max(mod1.k,0))*if(down(try catch(mod1.nitf.mu,-1))!=-1,(up(mod1.T)-down(mod1.T))*down(test(mod1.T)),(down(mod1.T)-up(mod1.T))*up(test(mod1.T)))/mod1.nitf.Tplus)*(dvol),{if@21}),mod1.k)
The initial of mu is not zero, it is the density of the material Air, and PE.
Hello everyone, I had the same problem, you can see my problem: Failed to find consistent initial values. Attempt to evaluate negative power of zero. Function: ^ Failed to evaluate expression. Expression: d(d((up(mod1.nitf.rho)*up(mod1.nitf.Cp)*mod1.nitf.C mu^0.25*sqrt(max(mod1.k,0))*if(down(try catch(mod1.nitf.mu,-1))!=-1,(up(mod1.T)-down(mod1.T))*down(test(mod1.T)),(down(mod1.T)-up(mod1.T))*up(test(mod1.T)))/mod1.nitf.Tplus)*(dvol),{if@21}),mod1.k) Last time step is not converged. The initial of mu is not zero, it is the density of the material Air, and PE. I don't find a way to solve this problem, if you succeed can you say me how you did please?
Posted: 1 decade ago 2011/09/19 0:13 JST
Hello everyone,
Function: ^
There is only one ^ in your expression, try "mu+eps" to see whether it works or not.
[QUOTE] Hello everyone, I had the same problem, you can see my problem: Failed to find consistent initial values. Attempt to evaluate negative power of zero. Function: ^ Failed to evaluate expression. Expression: d(d((up(mod1.nitf.rho)*up(mod1.nitf.Cp)*mod1.nitf.C mu^0.25*sqrt(max(mod1.k,0))*if(down(try catch(mod1.nitf.mu,-1))!=-1,(up(mod1.T)-down(mod1.T))*down(test(mod1.T)),(down(mod1.T)-up(mod1.T))*up(test(mod1.T)))/mod1.nitf.Tplus)*(dvol),{if@21}),mod1.k) Last time step is not converged. The initial of mu is not zero, it is the density of the material Air, and PE. I don't find a way to solve this problem, if you succeed can you say me how you did please? [/QUOTE] There is only one ^ in your expression, try "mu+eps" to see whether it works or not.
Posted: 1 decade ago 2013/07/20 5:27 JST
Hello everyone,
Function: ^
Have you guys solved this typical problem? I am always caught this problem...
[QUOTE] [QUOTE] Hello everyone, I had the same problem, you can see my problem: Failed to find consistent initial values. Attempt to evaluate negative power of zero. Function: ^ Failed to evaluate expression. Expression: d(d((up(mod1.nitf.rho)*up(mod1.nitf.Cp)*mod1.nitf.C mu^0.25*sqrt(max(mod1.k,0))*if(down(try catch(mod1.nitf.mu,-1))!=-1,(up(mod1.T)-down(mod1.T))*down(test(mod1.T)),(down(mod1.T)-up(mod1.T))*up(test(mod1.T)))/mod1.nitf.Tplus)*(dvol),{if@21}),mod1.k) Last time step is not converged. The initial of mu is not zero, it is the density of the material Air, and PE. I don't find a way to solve this problem, if you succeed can you say me how you did please? [/QUOTE] There is only one ^ in your expression, try "mu+eps" to see whether it works or not. [/QUOTE] Hi, Have you guys solved this typical problem? I am always caught this problem...
Posted: 1 decade ago 2013/07/20 5:29 JST
Cheers,
Alexis
Hi Alex,
Thanks a lot for your mentioning this model for the self define plastic model, but have you tried self define flow rule in your own plastic law in comsol?
Thanks.
Chaney
[QUOTE] Thanks for your answer, I have succeed to create my plastic law by studying the COMSOL model: elastoplastic_plate. Cheers, Alexis [/QUOTE] Hi Alex, Thanks a lot for your mentioning this model for the self define plastic model, but have you tried self define flow rule in your own plastic law in comsol? Thanks. Chaney
Posted: 8 years ago 2016/12/17 1:39 JST
Alexis
Xiaoyi Yu,
I'm having the same problem to model an adsorption column using Freundlich isotherm. My initial value of u1 is zero. Could you give me some help?
- Function: ^
- Expression: dvol*(-(-(((c0*(n*((comp1.u1*c0)^(n-1))))*KF)*(1/q0))))
Failed to evaluate Jacobian of expression.
- Expression: dvol*(-(((comp1.u2*S)+comp1.u2t)-((((comp1.u1*c0)^n)*KF)/q0)))
- Expression: (-(comp1.u2t+S*comp1.u2-KF*(c0*comp1.u1)^n/q0)*test(comp1.u2))*(dvol)
- Feature: Time-Dependent Solver 1 (sol1/t1)
João
[QUOTE] [QUOTE] I have the same problem. I think COMSOL wants to derive this equation. If you derive x^(2/3) the results is (2/3)x^(-1/3) so there is a negative power. I don't find a way to solve this problem, if you succeed can you say me how you did please? Alexis [/QUOTE] Your are right. In my model, the initial value of fc is zero, so I just plus an very small number eps, and it worked. [/QUOTE] Xiaoyi Yu, I'm having the same problem to model an adsorption column using Freundlich isotherm. My initial value of u1 is zero. Could you give me some help? Attempt to evaluate negative power of zero. - Function: ^ Failed to evaluate expression. - Expression: dvol*(-(-(((c0*(n*((comp1.u1*c0)^(n-1))))*KF)*(1/q0)))) Failed to evaluate Jacobian of expression. - Expression: dvol*(-(((comp1.u2*S)+comp1.u2t)-((((comp1.u1*c0)^n)*KF)/q0))) Failed to evaluate Jacobian of expression. - Expression: (-(comp1.u2t+S*comp1.u2-KF*(c0*comp1.u1)^n/q0)*test(comp1.u2))*(dvol) - Feature: Time-Dependent Solver 1 (sol1/t1) Regards, João
