2 decades ago
2009/12/02 12:55 JST
I've used general forms to describe Navier Stokes equations.... it's quite easy...
check this files
sts.bwk.tue.nl/hamlab/readers/COMSOL_SFunction.zip
have fun!
check this files
http://sts.bwk.tue.nl/hamlab/readers/COMSOL_SFunction.zip
have fun!
2 decades ago
2009/12/03 0:54 JST
Thank you. I'll try out the comsol files. Will they run undependently of the mat;lab files?
Regards
TedSmith
Regards
TedSmith
2 decades ago
2009/12/03 1:33 JST
Thanks again for the files. They mph files work fine. Not used the MATLAB interface yet so can't follow the M files yet.
I can't understand the problem you are trying to solve. Do you have any documentation that shows how you have converted the N-S equations to the general form? That would be very helpful. I want to obtain pressure from this solution and also want to restrain it from becoming negative.
Regards
Ted Smith
Regards
Ted Smith
2 decades ago
2009/12/04 7:02 JST
Of course... here is the model equations...
2 decades ago
2009/12/04 7:21 JST
Thank you Edwin. I am going on a course next week on COMSOL so will learn a lot more! I had not realised that you must specify the momentum and continuity equations. The whole process seems to be much more complex than ANSYS and requires and understanding of vector mechanics (on which I am weak!). Why did you choose COMSOL?
Regards
Ted
[QUOTE]
[/QUOTE]
Regards
Ted
Jim Freels
mechanical side of nuclear engineering, multiphysics analysis, COMSOL specialist
2 decades ago
2009/12/04 12:02 JST
Follow up to your last question, but reply to your original question. One cannot solve a general set of equations with ANSYS, only what they provide you. Naturally, solving your own set of equations becomes more difficult. Hence, the reason some people prefer not to have so much power !
2 decades ago
2009/12/05 9:00 JST
Edwin,
I am just curious. Is there a reason why you didn't use one of COMSOL's built in multiphysics coupling models (as in fluid/thermal interaction in the COMSOL base module)?
Ozgur
Edwin,
Ozgur
2 decades ago
2009/12/08 19:05 JST
Grupo ...Thanks a lot for the model.
I tried to do the same thing long time ago but I did not manage how to do so.
Now I know how :-)
Now I know how :-)
2 decades ago
2009/12/09 3:50 JST
this has really helped. In my problem, I have a moving wall (no-slip, u1=U, u2=0) , two outlets (at zero pressure, i.e. u3=0) and a stationary, no-slip wall (u1=0,u2=0) .
How would you put in the bc's in the three equations?
By the way, why did you use 2 separate pdes for the 2 momentum equations, rather than 1 with 2 dependent variables?
Regards
Ted
Regards
Ted
2 decades ago
2009/12/14 3:56 JST
Hi .. I'm glad to hear this files were useful for you, the main advantage of the pde general form is that you have complete power on the way you implement your pde's system.... I'd rather to implement 2 separate momentum equations because that's the way my model was defined, if you check my equations, those are not defined as tensors, those are defined as scalar equations....of course, you are free to implement your model equations whatever you want..
Kind regards
Kind regards
2 decades ago
2010/01/09 5:48 JST
Just wanted to say thanks for the posts. I found the comments and files exceedingly helpful!
Jim Freels
2 decades ago
2010/01/10 4:21 JST
Try this example right off the COMSOL model exchange:
www.comsol.com/community/exchange/62/
http://www.comsol.com/community/exchange/62/
10 years ago
2015/07/29 7:35 JST
Thank you for sharing the link. Unfortunately the link is not working anymore. Could you please share it again?
