does geometry made to make meshing easier effect the results?
Posted 2011/05/27 10:14 GMT-4 Geometry, Mesh Version 4.1 2 Replies
I am currently working with a Composite panel, for which I have two circular extrusions of metal on the surface but not through the panel. But that way to mesh the whole model I need to use tetrahedral mesh which is not a good way of meshing. To use a swept mesh I have to extrude the circular extrusions through the thickness of the panel in the middle but that extruded part is of course the composite material and not the metal, however, I am worried that can this alteration effect my results like I am to study the current and voltage propagation through this panel so I am not sure if I should be using this technique to handle the mesh or leave it and mesh with tetrahedral elements anyway which is taking a long time to mesh about 15 hours!
Rabia
Rabia
2 Replies Last Post 2011/06/06 13:47 GMT-4
