Recovering full solution when using solver sequence in GUI
Posted 2009/07/10 15:00 GMT-4 1 Reply
I am working with a model that has an abrupt change in the source term. This tends to bottleneck my system because the non-linear solver requires very small time steps in order to converge. I have been using the solver manager to set up a sequence that uses large time steps where the source term is constant and very small time steps where the source term changes. This is very intuitive and seems to solve the system just fine. However, when the solver finishes I only have access to the solutions for the last time sequence. I would like to be able to access the solution to all times solved by the sequencer. I understand that this sort of thing would be very simple to do using a Matlab script but since the computer I am working on doesn't have access to Matlab, I was hoping to find a way to do this within the COMSOL GUI.
Thank you for your help.
Mike
Mike
1 Reply Last Post 2009/07/16 17:44 GMT-4
