How to plot a variable depending on both position and time in 3D surface
I have a 2D model. some variables are both depending on time and x-position. I want to do a surface plot for these variables and I could do it in 3.5. but can I use COMSOL 4.1 to do this?
Thanks very much
1 Reply Last Post 2011/05/31 14:17 JST
Posted: 1 decade ago 2011/05/31 14:17 JST
the Results node is indeed different from 3.5. But it's "just" a new way and I find now, easier and more powerful to use. Check the doc again and do some of the examples.
A plot is normally done for (x,y,z) as a surface plot on a 3D Plot node, or for (x,y) a surface plot on a 2D Plot node. The time is defined ont he main plot node
Hi the Results node is indeed different from 3.5. But it's "just" a new way and I find now, easier and more powerful to use. Check the doc again and do some of the examples. A plot is normally done for (x,y,z) as a surface plot on a 3D Plot node, or for (x,y) a surface plot on a 2D Plot node. The time is defined ont he main plot node -- Good luck Ivar
