How to set a maximum temperature
Carl Philipp Benthaus
Hey! I have a model with a heat source heating up a cylindrical workpiece. I also considered the energy necceserary to change from solid to melted and from melted to evaporated material. Some parts of this workpiece exceed now during the process the evaporation temperature by far. But this is nonsense, because obviously it cannot, because the evaporated material is being removed from the workpiece. Now is the question: How can I set up a maximum temperature for my material?
Thanks in advance!
Carl
1 Reply Last Post 2018/07/25 7:07 GMT-4
Posted: 7 years ago 2018/07/25 7:07 GMT-4
Hi Carl,
You can go to: "Model 1" -> right click on "Definitions" -> "Component Couplings" -> "Maximum". In here, select the domain that you want to evaluate the maximum. To use this as a boundary condition take not of the name that COMSOL gives to your operator, by default it is "maxop1". In your BC you can use an if condition: if(maxop1(T)>300 [K], A,B). Note that when you define the maximum operator you can choose how COMSOL evaluates it, by default it is set to "node points", which means it evaluates just the nodes of your mesh (don't know much about the others, sorry). It is important to bare in mind that your should have a good mesh and a well-defined problem in order to know that your maximum is not just a hotspot but it indeed represents the physical results of your problem.
Best, Nichal
Hi Carl, You can go to: "Model 1" -> right click on "Definitions" -> "Component Couplings" -> "Maximum". In here, select the domain that you want to evaluate the maximum. To use this as a boundary condition take not of the name that COMSOL gives to your operator, by default it is "maxop1". In your BC you can use an if condition: if(maxop1(T)>300 [K], A,B). Note that when you define the maximum operator you can choose how COMSOL evaluates it, by default it is set to "node points", which means it evaluates just the nodes of your mesh (don't know much about the others, sorry). It is important to bare in mind that your should have a good mesh and a well-defined problem in order to know that your maximum is not just a hotspot but it indeed represents the physical results of your problem. Best, Nichal
