7 years ago
2018/07/26 4:55 JST
Hi Henry,
COMSOL chooses a small timestep, usually smaller than the one you define. Throughout the simulation it can increase it or decrease it depending on the changes it sees. If you want to have full control of the timestep go to "Study" -> "Solver Configurations" -> "Solution" -> "Time-dependent solver" -> "Time stepping" and in "Steps taken by solver" select strict to be sure that COMSOL just goes through the timestep you defined.
This might be of interst to you: https://www.comsol.pt/support/knowledgebase/1062/
Additionally, if you want to see the times taken by solver see the log file in the "Time dependent solver"
Nichal
Hi Henry,
Nichal
7 years ago
2018/07/26 5:14 JST
Hi Nichal,
I've done this, but the log window is saying that the stepper is still taking steps ~1e-7. Could it be possible that I've somehow defined a time step elsewhere that it is using? All the study nodes im checking have a the desired time step of .1s.
Thanks, Henry
Hi Nichal,
Thanks, Henry
7 years ago
2018/07/26 5:18 JST
That's odd. In the log itself you have "Tfail" and "NLfail". Do you have a relatively large number there? If your Tfail is high your problem must be the time step that you are setting too high. If your NLfail is high you should refine your mesh.
If you attach your model I can have a look!
7 years ago
2018/07/26 5:34 JST
The TFail remains 0, whereas the NLFail slowly increases to with each time step. NLFail went from 0 to about 100, although I cancelled the computation before time was over. I've refined the mesh as much as possible and this had seemingly no effect. I've attached the model below.
One concern I've had that may be playing a role is that my model was imported as a CAD model, so it might be very sophisted even for extremely fine meshes (although I suspect this is not the case as I feel like I've seen more complicated models on the tutorials before). Maybe there is a way to simplify the mesh while maintaining some accuracy?
Thank you so much for your help.
Best, Henry
Best, Henry
7 years ago
2018/07/26 5:39 JST
Unfortunately I cannot not open your model because my version is 5.1 and you created it with 5.3. I don't know if it is possible to save as an older version of COMSOL. If you how to do it and reattach it I can see it. Sorry...
7 years ago
2018/07/26 5:59 JST
I've attached the application as a .java file that you can compile on your own computer if you want to try that. However I don't know if this will work as I've never done it before, so we may just be out of luck. If that is the case no worries, as I can take this issue up with the support team (they take a while to respond sometimes which is why I came to the discussion boards first).
-Thanks, Henry
-Thanks, Henry
7 years ago
2018/07/26 18:32 JST
Hi Henry,
I've spent some time trying to compile it but I was not successful. My apologies.
Maybe someone else can try to see your file and help you
Kind regards,
Nichal
Hi Henry,
Kind regards,
Nichal
