Hello Muhammad Mohsin Rehman
2011/08/19 18:02 JST
I have the same problem... Did you fix it?
Nicolas
Nicolas
2011/10/06 4:01 JST
Not yet!
What about you now?
Not yet!
What about you now?
2011/10/06 7:01 JST
You have to change the mesh parameter. The reason I think is that your mesh parameter is too high.
Nicolas
Nicolas
2011/10/06 15:20 JST
what do you mean by too high?
I tried to change the mesh from Normal to Fine, but it continued to run for almost 10 hours without either giving error or results...After 10 hours, I stopped the simulation by myself.
2012/03/21 18:36 JST
I have the same problem :(
I am working on a solid oxide fuel cell. The solver starts to work but after few iterations it stops with same error : NaN or Inf found when solving linear system using SOR.
Did anybody find the source of problem and solution?
Omid
Omid
2012/03/22 10:03 JST
I am sorry for answering that late but I have stopped working on the project I was on. When you wreate the mesh you can create smal triangles and you can increase the size of them. When you the message "Nan..." it means that the mesh y ou try to create are to small (i.e you want a too accurate result). Start with coarse mesh and it should work (I think).
2013/04/30 8:37 JST
Hi there, I know this thread is old, but I am encountering the same error report in a model I am building for a microstrip patch antenna for the THz regime. Everything builds well but it won't even go over one iteration and the error Detail: NaN or Inf found when solving linear system using SOR. pops up claiming that an undefined value was found. I can't seem to find out what the undefined value is.
I tried simply making the mesh more coarse but that didn't accomplish anything. I'm a little lost and in need of some help! Has anyone else encountered this problem and found a solution?
2013/05/04 4:45 JST
Hi Regan,
I have the same problem, I am simulating a nano antenna, but I had lots of errors in Meshing and Comsol did not let me to use coarser meshes. I finally found a way to mesh my model without errors, but when I run it I see this NaN... error. Did you find any solution?
Hi Regan,
2014/01/06 6:32 JST
I am getting this problem in a very simple model I created just for testing (dipole radiating in an air cube). Did you find a solution?
2014/02/27 16:48 JST
Hello people I am facing this problem as well. I am trying to simulate ring resonator coupled with a waveguide on a substrate. As soon as I click the "compute" button it shows me the error in message box as:
Undefined value found.
- Detail: NaN or Inf found when solving linear system using SOR.
- Feature: Stationary Solver 1 (sol1/s1)
- Error: Undefined Value found
I tried to make the mesh coarse and even extremely coarse but it didnt help.
9 years ago
2016/10/11 21:12 JST
I am trying to solve the coupling between a waveguide and a microring resonator. I am following the same model as Comsol provide us on the web. The problem is that when I run my model this message appear:
-Detail: NaN or Inf found when solving linear system using SOR.
Could anyone help me, please?
