[4.1] extrusion 2D-axi in 3D
Hi everybody.
This is my problem : I import temperature map which is calculated in 2D-axi and I want to calculate the stress in 3D. I don't find how to extrude this variable in a new geometry. I don't know if I have to create a new model with 3D geometry or if I can extrude geometry also.
I remember I didn't have problem in version 3.5 because I follow example : "2D Axi-symmetric transient heat transfer". Do you know if here is same simple example for extrude variable with version 4.1?
Thank you for your time, Benjamin.
2 Replies Last Post 2015/10/30 17:33 JST
Posted: 1 decade ago 2011/06/17 0:14 JST
Hi, it's me again.
I made a mistake in my example. This is what I use for comsol 3.5 : www.comsol.fr/support/knowledgebase/982/
As you can see there is a very detailled example to extrude 2D-axi variable in a 3D variable that we can use in a 3D physics later. Do you know if this example existing in version 4.1 or something likeness?
Thank you, Benjamin Gallien.
Hi, it's me again. I made a mistake in my example. This is what I use for comsol 3.5 : http://www.comsol.fr/support/knowledgebase/982/ As you can see there is a very detailled example to extrude 2D-axi variable in a 3D variable that we can use in a 3D physics later. Do you know if this example existing in version 4.1 or something likeness? Thank you, Benjamin Gallien.
Posted: 10 years ago 2015/10/30 17:33 JST
Hi Benjamin, I'm trying to do the same but the link is broken, can you help me with some advice, or any document or link.
