Change Entity Numbering
Hi, I am an student and want to use Comsol for the mesh generation. It would be important for me that the geometric entity index 1 is assigned to a specific geometric entity. As far as I understood so far the geometric entity 1 will be the geometric entity of the first element, which is likely in the top left corner (in 2D). So I would have to change the numbering of the elements or the numbers of the geometric entities. How can I do this?
Edit: just to be clear, I speak about the geometric entity indices found in the mphtxt file
Edit2: Currently I didn't get an answer. In case the reason is that my question was not understood, just tell me and I will try to formulate my question better.
Edit 3: Ok, it might be sufficient if I just knew how to change the domain numbers, before the mphtxt file is created in the meshing.
0 Replies Last Post 2011/07/04 6:12 GMT-4
Hello Samuel Andermatt
