Hello Yoann Many
2011/09/09 21:49 JST
I'm interested in this topic, too.
Is there anyone who could explain it?
Thx so far
Thx so far
2011/09/10 17:25 JST
my understanding of the segragated steps are that you might groupe some dependent variables, solve for these and then use the results to solve again with the other set of comlementary dependent variables and then loop around until all variables have reached a reasonnable solution (global estimator is small).
This is particularly useful when you have either independent physics that are wekly linked, or a fast and a slow process. Basically you need less RAM andit solves quicker than if you put everything into the same pot and take all dependent variables in one go.
Then selecting which variables to choose first, second etc is a little tricky, COMSOL tries and achieves it quite well I find, often I can solve everything in one go, sa I have quite some RAM at hand (48Gb), at least for "small models" other times, when you have linked the variables in a way COMSOl does not see (i.e. via material properties etc) COMSOL suggests to regroup all variables in one step..
hope this helps
By the way do not forget the "LM"s that appear when you add complec BC
hope this helps
2011/10/11 6:49 JST
If for some reason, you end up having only one segregated step for all variables, then will this be the same as using a fully coupled solver?
Sirisha
Sirisha
2011/10/11 21:14 JST
no in all cases it a fully coupled solver, the only thing is that the solver loops around in a segregated way.
I would rather say one segregated step = direct solving (TBC it's my first reaction)
