how to set output of an stationary model as initial value for a time dependent model?
Posted 2011/07/06 11:54 GMT-4 Modeling Tools & Definitions Version 4.1, Version 4.2 10 Replies
I have a model consisting of two equations(one stationary and one time dependent). answer of first equation is initial condition for the second. solution of each equation is OK. but i do not know how to couple two equations?
Normally I add an stationary study, then I add a time dependent study to this study, then i use "show default solver" and after that i try to run the study but it does not work.
can anyone help me?
please find the attachment. stationary and time dependent studies are working properly.
but coupling two solution is not successful.
kind regards,
Mohammad
could you please let me know if you had solved the problem? I am working on similar problem. Also are you using COMSOL 3.5a?
yes i've found the soluiton. I'm working with 4.2
and how did you solve the problem? I have a similar problem, so it might help to know what you did.
Regards
Hannah
you can set two studies, first stationary and then time dependent. choose solver at the time dependent solver, afterwards select dependent variables, u can set the input parameters from another solver.
goo luck,
Mohammad
Would you please send your successful coupling file to me? I have the same problem. Many thanks.
Lanju
Suggested Content
- BLOG Guidelines for Modeling Rotating Machines in 3D
- KNOWLEDGE BASE Controlling the Time Dependent Solver Timesteps
- KNOWLEDGE BASE Solving time dependent models with inconsistent initial values
- FORUM initial value for stationary and time dependent solver
- FORUM Stationary solution as initial value for time-dependant study
