fir,fir if Number of all possible eigenvalues, 3D graph from 2D slices
Due to rf exampe about step index fiber.
1) how to script situation when number of eigenvalues is not known and i need to find all possible eigenvalues for different wavelengths.
I.e. SIF are single mode at certain wavelength, at other wavelengths more modes appear.
I need to find and to save possible eigenvalues at certain wavelengths.
I was able to find only first eigenvalue in *.mat file, but there is 1-36, depending on wavelength.
2)
the "if" in "for" do not work. The code below gives fatal error.
for ind=1:length(lambn),
for i=1:length(fem.sol.lambda),
if (i==1, neffs1(ind1)=real( fem.sol.lambda(1)*lambn(ind)*1e-3/(2*3.14), 0 );
if (i==1, ind1=ind1+1, 0 );
if (i==2, neffs2(ind2)=real( fem.sol.lambda(2)*lambn(ind)*1e-3/(2*3.14), 0 );
if (i==2, ind2=ind2+1, 0 );
end,
end,
If lines which contains "if" are commented, the script works.
I need to save all possible eigenvalues from each iteration.
ind1 and ind2 were initialized =1
ind comes from outer "for", looping through wavelengths
3) Is it possible to made 3D graph from 2D slices.
regards,
gintare
0 Replies Last Post 2009/07/14 15:14 JST
Hello gintare statkute
