Increasing the speed of computation
Hi all, I'm using RF module to do the calculations about photonic crystals. But it takes about 10 hours on the workstation which has more cores and memory than my laptop but takes almost the same time. Is there any way to increase the speed? Or is there a parallel version COMSOL for workstation? Thanks! Shengyan
1 Reply Last Post 2018/09/02 1:47 JST
Posted: 7 years ago 2018/09/02 1:47 JST
Most of the solvers will take advantage of multiple cores, during the main part of the solution stage. Check your settings and check to see if the cores are being utilized. Also, consider your meshing (which may be finer than necessary) and the element discretization. You may be able to work with linear, rather than the default quadatic elements. There are enormous differences in speed and memory requirements, depending on the choices of the solvers and the discretization of the elements. So be sure to learn all about them.
