How to define "step velocity"?
Hello to all,
Could you please help me to how can I define "step velocity" as in for first 0.5 sec velocity is zero then for next 2 second it is 1 m/s and again zero for next 0.5 sec.?
4 Replies Last Post 2018/09/11 2:43 JST
Mickaël Barsive COMSOL Employee
Posted: 7 years ago 2018/09/10 18:21 JST
You can use a rectangle function in "Definitions">"Functions">"Rectangle".
In your case, set "lower limit" at 0.5, "upper limit" at 2.5 then you can plot the graphic to check your function. The next step is to use the function in the physics interface: in your "Inlet" node, you can use the following syntax: rect1(t[1/s]) rect1 is the function name by default and [1/s] is used for homogeneous units.
I hope this helps !
Mickaël
Hello, You can use a rectangle function in "Definitions">"Functions">"Rectangle". In your case, set "lower limit" at 0.5, "upper limit" at 2.5 then you can plot the graphic to check your function. The next step is to use the function in the physics interface: in your "Inlet" node, you can use the following syntax: rect1(t[1/s]) rect1 is the function name by default and [1/s] is used for homogeneous units. I hope this helps ! Mickaël
Posted: 7 years ago 2018/09/11 0:12 JST
I hope this helps !
Mickaël
Thank you very much for your help.
>Hello, > >You can use a rectangle function in "Definitions">"Functions">"Rectangle". > >In your case, set "lower limit" at 0.5, "upper limit" at 2.5 >then you can plot the graphic to check your function. The next step is to use the function in the physics interface: in your "Inlet" node, you can use the following syntax: rect1(t[1/s]) >rect1 is the function name by default and [1/s] is used for homogeneous units. > >I hope this helps ! > >Mickaël Thank you very much for your help.
Posted: 7 years ago 2018/09/11 0:39 JST
rectangular velocity steps will probably stop a time dependent solver as a velocity step implies infinite acceleration and thus is unphysical. You may need to smooth the steps. This can be done with e.g. ramp functions. Take care that the time stepping properly resolves the ramp.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi, rectangular velocity steps will probably stop a time dependent solver as a velocity step implies infinite acceleration and thus is unphysical. You may need to smooth the steps. This can be done with e.g. ramp functions. Take care that the time stepping properly resolves the ramp. Cheers Edgar
Jeff Hiller COMSOL Employee
Posted: 7 years ago 2018/09/11 2:43 JST
Hi Edgar,
The Rectangle function includes (adjustable) smoothing - See GUI.
Jeff Hiller
Hi Edgar, The Rectangle function includes (adjustable) smoothing - See GUI. Jeff
