electrical capacitance tomography model_wrong capacitance reading
hi,
i am working on the simulation of electrical capacitance tomography sensor. i have built the model in comsol4.0a and have simulated it. i have some doubts regarding the same and are listed below.
1. i use the formula 'es.C21' to calculate capacitance in global evaluation. the resultant capacitance value comes with a minus (-) sign.why is it so?
2. i choose plate7 and plate6 as terminals. and calculate the capacitance. when the sensing volume(ie. cavity inside the pipe) contains only air,i get capacitance around 1.944e-12. and when i place a cylindrical object made up of PVC/water/silicon or any other dielectric, i get capacitance value approximately 1.91e-12 which is lesser than the earlier. and this is contradictory to the facet that capacitance of a capacitor increases when a dielectric of a higher dielectric constant is placed between the plate. what could be the mistake?
i am trying to attach the file but there seems to be some problem with the file size limit.the file size is 17MB.is there any alternative?
regards,
Hrishikesh
2 Replies Last Post 2012/03/12 20:23 JST
Posted: 1 decade ago 2011/07/22 17:37 JST
i have shared the model in model exchange with the name 'electrical capacitance tomography sensor'.
Nor Muzakkir Nor Ayob
Posted: 1 decade ago 2012/03/12 20:23 JST
interesting problem, however i cant find the mentioned model in the model exchange.
[QUOTE] i have shared the model in model exchange with the name 'electrical capacitance tomography sensor'. [/QUOTE] interesting problem, however i cant find the mentioned model in the model exchange.
