Non-convergence P2-P1 lagrange elements
I am doing some CFD on a laminar case, and it appears that my study converges well when I use P1+P1 elements, but it doesn't converge at all when using P2+P1 elements!
Any clue on why this could happen? It doesn't happen when using simpler geometries...
3 Replies Last Post 2011/07/29 3:01 JST
Posted: 1 decade ago 2011/07/28 12:03 JST
I have the same problem! Any luck yet?
Sirisha
I have the same problem! Any luck yet? Sirisha
Posted: 1 decade ago 2011/07/28 17:55 JST
Unfortunately not....
I tested it on a simpler geometry and it also caused some problems. When reducing the Reynolds number it's better and I get convergence in P2-P1, but that doesn't really solve the problem...
Let me know if you are more lucky than I !
Guillermo
Unfortunately not.... I tested it on a simpler geometry and it also caused some problems. When reducing the Reynolds number it's better and I get convergence in P2-P1, but that doesn't really solve the problem... Let me know if you are more lucky than I ! Guillermo
Posted: 1 decade ago 2011/07/29 3:01 JST
Based on version 4.2 manual, P2-P1 is recommended for creeping flows. I am still using version 4.1 but I refer to the new manual because it has more details than the old manual.
My problem is that, with P2-P1 elements and a direct solver, I am able to achieve convergence with a coarse mesh. However when I use P2-P1 elements and a direct solver with a finer mesh, then I am unable to achieve the convergence.
Also, when I use the coarse mesh, I am running it using the COMSOL GUI on my desktop but when I use the fine mesh, I use batch mode and run it on a server. Not sure if that is making a difference. I cannot run the fine mesh on the desktop because the problem needs more memory than what my desktop can provide.
I am hoping someone has an answer for this problem!
Sirisha
Based on version 4.2 manual, P2-P1 is recommended for creeping flows. I am still using version 4.1 but I refer to the new manual because it has more details than the old manual. My problem is that, with P2-P1 elements and a direct solver, I am able to achieve convergence with a coarse mesh. However when I use P2-P1 elements and a direct solver with a finer mesh, then I am unable to achieve the convergence. Also, when I use the coarse mesh, I am running it using the COMSOL GUI on my desktop but when I use the fine mesh, I use batch mode and run it on a server. Not sure if that is making a difference. I cannot run the fine mesh on the desktop because the problem needs more memory than what my desktop can provide. I am hoping someone has an answer for this problem! Thanks Sirisha
