element order and convergence
I have a FSI problem that converges when I use first order elements for pressure and velocity and second order for displacements. But I am not happy with the results I am seeing. Hence I changed the element order.
I am using second order elements for the velocity and displacement and first order for pressure. Now the problem is not converging.
It should not be behaving this way because I think that increasing the order of the element should give better convergence. Am I wrong? Did anybody face a similar problem?
Sirisha
1 Reply Last Post 2014/04/12 21:17 JST
Hello Sirisha Govindaraju
Posted: 1 decade ago 2014/04/12 21:17 JST
Hi.
Check the Reynolds number for the fluid flow.
If the Reynolds number is high, the convective term in Navier-Stokes eqn is dominant, which is a nonlinear term.
Then, it's better to solve with first order element in velocity.
Second order element in velocity is good when the diffusive term is dominant.
Hi. Check the Reynolds number for the fluid flow. If the Reynolds number is high, the convective term in Navier-Stokes eqn is dominant, which is a nonlinear term. Then, it's better to solve with first order element in velocity. Second order element in velocity is good when the diffusive term is dominant.
