Specify file name to import as a parameter
Posted 2018/11/09 18:48 JST Interfacing, Geometry 2 Replies
Hi there,
Is there a way to specify which DXF file to import as a polygon in a work plane, using a parameter?
I'm generating the structures I want to study using a (Python) script that exports them as DXF files. Typically, I vary some parameters to optimize the structures, so I'll end up with a folder filled with (slightly different) DXF files. Ideally, I would like to loop over the files in this folder using a COMSOL Parametric Sweep, for example by using the file name as a sweep parameter. Is this possible?
Thanks!
