Simulation of phase transformation inside a moving object
It is necessary to determine the period of time over which the water temperature (the initial state is ice) change from minus 30 degrees Celsius to plus 36 degrees Celsius. Water (the original state is ice) is in an airtight polymeric shell (it has the form of a pillow). Together with the shell, the ice makes reciprocating movements in the process chamber. The chamber is completely filled with constantly heated water, the temperature of which is 36 degrees. As a result of the movements, the water is mixed under the shell, and outside. It is important to model close to natural mixing. So far, I have not found examples of modeling phase transformation inside a moving object, the movement of which directly affects the speed of phase transformation Question I want to understand whether it is possible to moderate my task (in dynamics) in COMSOL? If so, can you find information on examples of such modeling?
1 Reply Last Post 2018/12/28 6:38 JST
Posted: 7 years ago 2018/12/28 6:38 JST
Your problem is quite complex but it can be simlified by just solving shell filled with ice as reciprocating sloshing tank ( Search for sloshing tank example). Use phase change materials in heat transfer module.
