2011/08/09 3:23 GMT-4
make a study with 2 steps, and normaly the second step will take the results of the first one as IC, and if there is less results data than IC, it will fill in with the IC of the first step (got it ^^??)
If you want to make sure, put in the second step "results from : store solution ", as store solution is the backup of the results for your first step....
Good luck!
Good luck!
2011/08/10 15:32 GMT-4
Yoann,
Yes, what you explained does make sense, but I can't figure out how to assign different loads (different heat sources in my case) to each step. I've tried adding another heat transfer set (so that I have ht and ht2 now), but it looks like each set of physics will be applied to each step of the solution, which is clearly not what I want.
A little further explanation would be greatly appreciated.
Thank you,
Theodore
Yoann,
Thank you,
Theodore
2011/08/10 16:18 GMT-4
Disable ht2 (transient) from the stationary study (Study 1 > Step 1: Stationary)
Disable ht (static) from the transient study (Study 2 > Step 1: Time Dependent)
Set Initial Condition of Dependent Variables in Time Dependent study to be the solution from Solver 1.
I don't have Comsol in front of me to tell you exactly, but this should be very close to the actual steps you need to take.
2011/08/13 13:52 GMT-4
sometimes you might manage to use a "Contination" or "Parametric" sweep of a "Parameter" to switch between ifferent load cases
