velocity profiles of pipe and annulus
Michael Rembe Certified Consultant
I have bad convergence using a constant velocity (v=Q/A) for a pipe inflow.
Using a parabolic velocity profile I get excellent convergence! The formula is v=2*Q/A*(1-r^2/R^2) with:
r - space coordinate of an axisymmetrical model
R- pipe radius
Does anybody know the formula of the velocity profile of an annulus (axisymmetrical model)?
Michael
4 Replies Last Post 2011/08/18 15:37 JST
Posted: 1 decade ago 2011/08/17 19:14 JST
in laminar regular flow for an isotropic model its approaching a parabola, that explains probably why you get a better convergence starting closer to the final solution
Hi in laminar regular flow for an isotropic model its approaching a parabola, that explains probably why you get a better convergence starting closer to the final solution -- Good luck Ivar
Posted: 1 decade ago 2011/08/17 19:24 JST
Hi Ivar,
yes, this is right. But now I'm looking for a velocity profile (laminar flow) for an annulus (two pipes into one another).
The formula should be similar to v=4*v_max*s*(1-s) in 2D, but just for a 2d-axisymmetric model
Michael
Hi Ivar, yes, this is right. But now I'm looking for a velocity profile (laminar flow) for an annulus (two pipes into one another). The formula should be similar to v=4*v_max*s*(1-s) in 2D, but just for a 2d-axisymmetric model Michael
Lechoslaw Krolikowski
Posted: 1 decade ago 2011/08/18 2:55 JST
Hi Michael,
Attached is the velocity profile you are looking for.
BR
Andrzej
Hi Michael, Attached is the velocity profile you are looking for. BR Andrzej
Posted: 1 decade ago 2011/08/18 15:37 JST
Hi Andrzej,
thank you very much for the velocity profile!
Best regards
Michael
Hi Andrzej, thank you very much for the velocity profile! Best regards Michael
