Meshing -- time and memory
Posted 2011/08/19 16:47 JST Mesh Version 4.2 1 Reply
Hi Everyone,
I have a reasonably complex geometry over which I want to create a mesh. Just to see what would happen, I selected "extremely coarse mesh" and hit build all. The result was that my computer spend about two hours allocating more and more memory and topped out at about 4.3 GB for Comsol private memory. Since this peak in memory, the memory usage is declining very slowly. About 18 hours after the peak, the memory usage was 3.2 GB.
My computer has 6GB RAM, so the RAM is large enough to fit this mesh. I have an i7 920 chip, which is a quad-core that supports a further division into two virtual cores per core, so effectively an octacore from the software point of view. During this entire computation, the total CPU load was exactly 12.5% all the time. This seems that Comsol is using one of the chips totally and none of the others. My OS is 64-bit Windows 7 Ultimate.
The questions in this are:
1. Why is Comsol using so little CPU power?
2. Why is meshing taking so long?
3. What meaning does it have that the mesh is at first large and then get smaller?
4. What can I do to provide Comsol with the full CPU speed and to hurry up the meshing?
5. If I select something other than "extremely coarse mesh" can I expect to finish in reasonable time, even if I upgrade my RAM?
Thank you!!
Thank you!!
1 Reply Last Post 2011/08/19 20:44 JST
