Curved / Branched Objects in COMSOL
Hi!
I would like to model "natural", curved objects, that include several branches of basic gemoetries - similar to the shape of a tree or palm.
Based on your experience, what is the best way to realize this in COMSOL, in terms of best compatibility with the meshing algorithm and avoiding topology and meshing errors?
*) Model directly in COMSOL
*) CAD Import from other Enviroments
*) LiveLink wiht SolidWorks
Thank you very much,
Paul
3 Replies Last Post 2011/09/08 20:30 JST
Posted: 1 decade ago 2011/09/06 15:08 JST
I use all with success, (almost: dxf and and some CAD software models are not true 2D/3D volumes, but collections of surfaces, these do not always knit into volumes, because of "small gaps")
Hi I use all with success, (almost: dxf and and some CAD software models are not true 2D/3D volumes, but collections of surfaces, these do not always knit into volumes, because of "small gaps") -- Good luck Ivar
Posted: 1 decade ago 2011/09/08 18:30 JST
Thank you Ivar!
One last question:
How would you proceed at importing a curved architecture defined in STL format?
I am running into geometry errors when generating a mesh, also if the form is very simplified (no small faces, etc).
Is it more recommendable to convert the STL to one of the CAD formats and import it with the CAD kernel?
Thank you & Best Regards
Paul
Thank you Ivar! One last question: How would you proceed at importing a curved architecture defined in STL format? I am running into geometry errors when generating a mesh, also if the form is very simplified (no small faces, etc). Is it more recommendable to convert the STL to one of the CAD formats and import it with the CAD kernel? Thank you & Best Regards Paul
Posted: 1 decade ago 2011/09/08 20:30 JST
I never import STL ! as these are layered 2.5D surfaces, and difficult to make into volumes, and their numerous "digital steps" are difficult to mesh.
Try out and change the meh size parameters, you might have more success if you turn off the small feature mesh effects and force a maximum size of a stl step, or somewhat less
Hi I never import STL ! as these are layered 2.5D surfaces, and difficult to make into volumes, and their numerous "digital steps" are difficult to mesh. Try out and change the meh size parameters, you might have more success if you turn off the small feature mesh effects and force a maximum size of a stl step, or somewhat less -- Good luck Ivar
