How to save a 3.5a file in a 3.3 version ?
I have created *.mph models with the 3.5a version. For my PhD, I am in collaboration with an other laboratory working with the 3.3 version of COMSOL. But, they can't open my model.
So, how I can convert my model in a 3.3 version ?
I really need your help...
Thanks a lot !
Gabriel.
5 Replies Last Post 2013/12/11 18:37 JST
Posted: 1 decade ago 2011/09/07 23:48 JST
I do not suppose its possible, you could try to dump it as a *.m file and tweak it to be 3.3 compatible. Hence the importance to get all partners to use the SAME version
Hi I do not suppose its possible, you could try to dump it as a *.m file and tweak it to be 3.3 compatible. Hence the importance to get all partners to use the SAME version -- Good luck Ivar
Posted: 1 decade ago 2011/12/16 22:43 JST
Ihave a similar problem but with version 4.2a. Is it possible to convert the file from 4.2a into 4.2?
Thank you!
Kalin
Hi, Ihave a similar problem but with version 4.2a. Is it possible to convert the file from 4.2a into 4.2? Thank you! Kalin
Posted: 1 decade ago 2011/12/17 5:43 JST
I do not believe "down" converting is possible, most programmes on the market only allows to read into newer versions. To be sure you must check with "support"
Hi I do not believe "down" converting is possible, most programmes on the market only allows to read into newer versions. To be sure you must check with "support" -- Good luck Ivar
Posted: 1 decade ago 2013/12/10 21:52 JST
now I have the same problem but I have Comsol 4.3b and I need to save it in Comsol 4.3.
It´s possible?
So, how I can convert my model in a 4.3 version ?
Thank you in advanced
Joaquim
now I have the same problem but I have Comsol 4.3b and I need to save it in Comsol 4.3. It´s possible? So, how I can convert my model in a 4.3 version ? Thank you in advanced Joaquim
Posted: 1 decade ago 2013/12/11 18:37 JST
It´s possible?
It isn't possible to open a model saved in 4.3b in 4.3. The workaround proposed earlier in the thread - going via an exported .java- or .m-file - might work, but there is no guarantee.
[QUOTE] now I have the same problem but I have Comsol 4.3b and I need to save it in Comsol 4.3. It´s possible? So, how I can convert my model in a 4.3 version ? [/QUOTE] It isn't possible to open a model saved in 4.3b in 4.3. The workaround proposed earlier in the thread - going via an exported .java- or .m-file - might work, but there is no guarantee.
