µ-Metal shield
Vladimir Gregorowitsch
Hi all,
i have an Inventor file with a µ-Metal shield i have designed. Now i want to simulate how good the shielding is. Is it enough ne apply a magnetic field (as a boundary condition) and to set the the magnetic permeability of the metall?
Thank you
5 Replies Last Post 2011/09/15 23:44 JST
Posted: 1 decade ago 2011/09/13 16:44 JST
Vladimir,
if the fields get the material near saturation you might need to define a non-linear permeability.
Cheers
Edgar
Vladimir, if the fields get the material near saturation you might need to define a non-linear permeability. Cheers Edgar
Posted: 1 decade ago 2011/09/13 18:47 JST
i will try it.
Vladimir
Thanks, i will try it. Vladimir
Posted: 1 decade ago 2011/09/15 0:33 JST
Hi, i have some Problems,
first i designed i mini setup. A big cube and a small metall part with high permiability inside. Now i want to see how the magnetic field in cube change if i apply a constant magnetic field.
But this is my Problem. how to define a constant magnetic field in the big cube, that i will be influenced by the high permiability? I i set the magnitic field in the whole volume then nothing will happen?
With best regards
Hi, i have some Problems, first i designed i mini setup. A big cube and a small metall part with high permiability inside. Now i want to see how the magnetic field in cube change if i apply a constant magnetic field. But this is my Problem. how to define a constant magnetic field in the big cube, that i will be influenced by the high permiability? I i set the magnitic field in the whole volume then nothing will happen? With best regards
Posted: 1 decade ago 2011/09/15 0:52 JST
Vladimir,
set the uniform field you want just on the outer boundaries (cube walls) this will result in a uniform field inside the cube and any magnetic object inside the cube will distort it. E.g. for a uniform field of 1T in z-direction set Bz=1T and Bx=0, By =0 on all outer boundaries.
Cheers
Edgar
Vladimir, set the uniform field you want just on the outer boundaries (cube walls) this will result in a uniform field inside the cube and any magnetic object inside the cube will distort it. E.g. for a uniform field of 1T in z-direction set Bz=1T and Bx=0, By =0 on all outer boundaries. Cheers Edgar
Posted: 1 decade ago 2011/09/15 23:44 JST
Great Thanks!
I got it :)
Great Thanks! I got it :)
