Selective meshing
After meshing the geometry using an extremely fine mesh, I would like to further increase mesh density in certain regions like the inlet and outlet of a microfluidic channel.
Can I do this in COMSOL 4.2?
I also want to use custom lines to plot 2D line graphs across the channel after I obtain the results.
How do I do this?
1 Reply Last Post 2011/09/22 14:57 JST
Posted: 1 decade ago 2011/09/22 14:57 JST
check the doc on mesing, you also have the mesh refinement nodes in v4, just as you can add several"distributions or sizes for different edges/boundaries to a meshing node to selectively control the meshing density
Hi check the doc on mesing, you also have the mesh refinement nodes in v4, just as you can add several"distributions or sizes for different edges/boundaries to a meshing node to selectively control the meshing density -- Good luck Ivar
