Frequency Selective Surface, Complementary Split Ring Resonator
Hi, I have a problem figuring out where can i find c1 which is being stated by no 2. please help. 1 On the Work Plane toolbar, click Booleans and Partitions and choose Difference. 2 Select the object c1 only.
3 Replies Last Post 2019/02/22 2:27 JST
Jeff Hiller COMSOL Employee
Posted: 7 years ago 2019/02/22 2:21 JST
Hello Rodolfo,
Look on the left edge of your screenshot and you'll see that there a geometry object called c1 in the Model Builder tree structure. In this case, it looks like it is the first circle you drew.
Jeff Hiller
Hello Rodolfo, Look on the left edge of your screenshot and you'll see that there a geometry object called c1 in the Model Builder tree structure. In this case, it looks like it is the first circle you drew. Best, Jeff
Posted: 7 years ago 2019/02/22 2:25 JST
Hi;
It says there that select object c1 only. How to input this? if i will click the c1 at the left it will return to previous steps that i have.
Hi; It says there that select object c1 only. How to input this? if i will click the c1 at the left it will return to previous steps that i have.
Posted: 7 years ago 2019/02/22 2:27 JST
I got it already, thanks. i need to click the manual to choose c1.
