How to use comsol on a linux server, I've got errors below.
Posted 2019/03/06 22:24 GMT-5 Version 5.3a 0 Replies
(comsollauncher:3421): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(comsollauncher:3421): GLib-GObject-CRITICAL **: g_signal_connect_data: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed
(comsollauncher:3421): Gtk-CRITICAL **: IA__gtk_settings_get_for_screen: assertion `GDK_IS_SCREEN (screen)' failed
(comsollauncher:3421): Gtk-WARNING **: Screen for GtkWindow not set; you must always set a screen for a GtkWindow before using the window
(comsollauncher:3421): Gdk-CRITICAL **: IA__gdk_screen_get_display: assertion `GDK_IS_SCREEN (screen)' failed
(comsollauncher:3421): Gdk-CRITICAL **: IA__gdk_display_get_pointer: assertion `GDK_IS_DISPLAY (display)' failed
(comsollauncher:3421): Gdk-CRITICAL **: IA__gdk_screen_get_n_monitors: assertion `GDK_IS_SCREEN (screen)' failed
(comsollauncher:3421): Gdk-CRITICAL **: IA__gdk_screen_get_monitor_geometry: assertion `GDK_IS_SCREEN (screen)' failed
(comsollauncher:3421): Gdk-CRITICAL **: IA__gdk_screen_get_default_colormap: assertion `GDK_IS_SCREEN (screen)' failed
(comsollauncher:3421): Gdk-CRITICAL **: IA__gdk_colormap_get_visual: assertion `GDK_IS_COLORMAP (colormap)' failed
(comsollauncher:3421): Gdk-CRITICAL **: IA__gdk_screen_get_root_window: assertion `GDK_IS_SCREEN (screen)' failed
(comsollauncher:3421): Gdk-CRITICAL **: IA__gdk_window_new: assertion `GDK_IS_WINDOW (parent)' failed
A fatal error has been detected by the Java Runtime Environment:
SIGSEGV (0xb) at pc=0x00000034cda7a486, pid=3421, tid=0x00007ff1aa34c700
JRE version: Java(TM) SE Runtime Environment (8.0_112-b15) (build 1.8.0_112-b15) Java VM: Java HotSpot(TM) 64-Bit Server VM (25.112-b15 mixed mode linux-amd64 compressed oops) Problematic frame: C [libgdk-x11-2.0.so.0+0x7a486] gdk_window_enable_synchronized_configure+0x16
Core dump written. Default location: /home/yrl/Scratch_Assay/core or core.3421
An error report file with more information is saved as: /home/yrl/Scratch_Assay/hs_err_pid3421.log
If you would like to submit a bug report, please visit: http://bugreport.java.com/bugreport/crash.jsp The crash happened outside the Java Virtual Machine in native code. See problematic frame for where to report the bug.
/home/yrl/comsol/bin/comsol: line 1613: 3421 Aborted (core dumped) ${MPICMD} ${FLROOT}/bin/${ARCH}/comsollauncher --launcher.ini ${LAUNCHERINIFILE} ${LAUNCHERARGS} ${MPILAUNCHERARGS}
Hello 仁龙 杨
