Pull force of a permanent magnet on an iron sheet
Posted 2019/03/10 20:29 GMT-4 Low-Frequency Electromagnetics, Parameters, Variables, & Functions, Equation-Based Modeling 2 Replies
Hi all,
I am currently trying to model the pull force of a permanent magnet when attached to the surface of an iron sheet.
I have currently used the 'force calculation' in the mfnc set up, and I am getting a value for the force which is definitely in the right ball park.
However, I have a couple of issues. One being that I do not know how to model an infinite plate. In reality the plate will be much greater in length than the magnet. However, increasing the length, considerably increases the run time and therefore I was wondering if there was a way to do so without having to actually model a very large plate.
The second issue is that the force calculated is very low when the magnet is actually touching the surface. It provides a much more realistic value when there is a small gap, however the value changes significantly with the size of the gap. I am not sure if this is because I need to add something to the model or whether or not it is down to me using the wrong method and actually calculating the pull force of the magnet incorrectly.
Any help would be much aprreciated, thanks in advance!
Owen
