                                2011/10/11 10:33 GMT-4
try to add a weak constraint on the variable and impose it to zero, rather by creating an new variable and make it piloted by the result to change your driving BC
PS it works smoother in the later versions ;)
                                2011/10/11 13:02 GMT-4
                                                    Hi Ivar,
Thank you very much for your reply.  i did try to impose it as a week constraint but instead of the constraint being imposed, the Lagrange multiplier became zero.  Is there a way to strictly enforce this condition?
Thanks.
Best
Lakshmi.
                            Hi Ivar,
Thanks.
Best
Lakshmi.
                                2011/10/11 16:22 GMT-4
yes by defult it optimises to "0" so ou must move all items to the left side of the equation, if you want to impose "u = 3" you should write "u - 3" in the field entry, when COMSOl imposes "=0" you will end up with "u=3"
Check the doc, and turn on the "equation view" in the preferences, and see how COMSOL handles weak constraints
                                2011/10/17 10:23 GMT-4
                                                    Hi Ivar,
Thanks for your reply.  I upgraded to COMSOL 4.2 now.  I understand that COMSOL optimises the constraint to zero.  But when I try to impose this constraint, a non symmetric matrix is formed and then it returns with a singular matrix error.  I have attached the file.  Please have a look and let me know what you think.
Thanks for your time.
Best
Lakshmi.
                            Hi Ivar,
Best
Lakshmi.
                                2011/10/18 7:30 GMT-4
try to avoid point and edge constraints in 3D, you are making singular points, and the solver will anyhow have difficulties to finds its way, and your results will at least be locally very wrong
Cut your surface with a cylinder and apply loads on a boundary, and use pressure, then you are sure you are perpendicular to  the surface. If you have large deformations, consider to turn the option on, it takes longer to solve and needs often more RAM, be aware
