2011/10/19 1:34 GMT-4
first of all, you need material properties on all domains, and sometimes also boundaries. You have two options toi define them: 1) (my preferred and COMSOL's default) use the material list, 2) use the physics nodes and change all material referring tabs to "user defined" + values
To find a domain, or boundary, (or edge or point) select the graphical setting to respectively domain, boundary, (edge or point) via the icon on the top right border of your graphical view. Then Alt-V (=View) and select "Selection List", then click on the domain ID value and it is highlighted in the graphics window
You can also go to a domain selection node add all and then click on the ID number, but its a poor way as you change your model, and you must not forget to undo your selection, without you might/will get some strange results
2014/04/02 10:41 GMT-4
How is the Selection List Window enabled in Comsol 4.4?
I can't find it, and there is no information about Selection List Window in the documentation for 4.4 (in contrast to earlier versions).
Is this feature still available?
Jeff Hiller
COMSOL Employee
2014/04/02 10:57 GMT-4
You can reach the Selection List window by selecting "More Windows" and "Selection List" in the Home ribbon, on a Windows machine. On Linux and Mac, you will find this under the Windows menu.
This is documented on page 10 and 122 of the Introduction to COMSOL Multiphysics manual, at least.
