Change the order of Geometry
In comsol4.2 can order of component of geometry be changed?
For example, I have mirrored some blocks. Then I add a new block and want this blck to be mirrored as other blocks. To do this, I must add a new mirror component. Can I use the first mirror component to mirror the added block? In other word, can I creat a new component the order of which is before a extanted one.
2 Replies Last Post 2011/10/25 17:05 JST
Posted: 1 decade ago 2011/10/24 20:28 JST
the id ordering of items comes from their location and is internal to COMSOL (from what I know). If you use matlab calls you can add in a geoemtrical object into an exisitng Mirror command, but I do not see how you can do this "automatically" within the GUI
Hi the id ordering of items comes from their location and is internal to COMSOL (from what I know). If you use matlab calls you can add in a geoemtrical object into an exisitng Mirror command, but I do not see how you can do this "automatically" within the GUI -- Good luck Ivar
Posted: 1 decade ago 2011/10/25 17:05 JST
Thank you very much. It seems that I can add a new mirror component to implement the mirror operation, even though it's a little inconvenient.
