Effect of moving boundary on fluid flow
Hi everyone,
I am trying to model the effect of moving a small circle within a larger rectangle on the fluid flow within the space between the circle and the rectangle; I use moving mesh module (ALE) and Incompressible navier-stokes module.
(I only have 1 subdomain which is the space between the circle and rectangle)
First I solve the ALE module: inner circle moves with the speed of 0.1 m/s in the x-direction while the rectangle boundaries are set to zero mesh displacement.
Then I use this result to see the effect of circle movement on the fluid velocity. This time I set all boundaries as walls.
But I get convergence error. Is it the correct way of studying the effect of moving boundary on the fluid flow?
Any help is highly appreciated.
Hesam
PS: I guess what I am trying to do is similar to this: www.youtube.com/watch?v=22ylDEEgPKI
1 Reply Last Post 2011/11/12 1:47 JST
Posted: 1 decade ago 2011/11/12 1:47 JST
I have a similar problem, but i dont know solve it. Did you solve your problem ?
Hello, I have a similar problem, but i dont know solve it. Did you solve your problem ?
