Surface plot: change x- and y-axis
Hi!
I made a surface plot showing soil temperatures in a borehole at different depths over time out of an extruded 2d cut line. Now I would like to change the axis: At the moment, the time is on the vertical axis and the depth is on the horizontal axis. The idea is now to have the time on the horizontal and the depth on the vertical axis.
Thank you for your help!
Kind regards,
Daniel
3 Replies Last Post 2011/11/08 0:38 JST
Posted: 1 decade ago 2011/10/28 2:21 JST
check carefully the plot nodes, you have either if you have the data in a 2D table an inner or outer parameter to go by lines or by columns, and in the 1D plot nodes you can define X and Y axis (slighly dependent on which 1D plot you choose) At least it's so now in 4.2a.
Hi check carefully the plot nodes, you have either if you have the data in a 2D table an inner or outer parameter to go by lines or by columns, and in the 1D plot nodes you can define X and Y axis (slighly dependent on which 1D plot you choose) At least it's so now in 4.2a. -- Good luck Ivar
Posted: 1 decade ago 2011/11/07 20:06 JST
Hi Ivar,
how do you change the size of the font for the axis of the plots? It turns out, when I print the pictures from the camera icon the scale numbers on the axis are normally too small!
Massimo
Hi Ivar, how do you change the size of the font for the axis of the plots? It turns out, when I print the pictures from the camera icon the scale numbers on the axis are normally too small! Thanks, Massimo
Posted: 1 decade ago 2011/11/08 0:38 JST
in v4.2a there is a "font" tab in the camera Gui, or in the export image tab, not sure when it appeared ;)
Hi in v4.2a there is a "font" tab in the camera Gui, or in the export image tab, not sure when it appeared ;) -- Good luck Ivar
