LiveLink, using a variable and for loop to change a parameter set
Hi all,
I would like to be able to change one parameter of my model inside of a for loop with LiveLink and then run the model. Does anyone know how to do this? My code looks something like this:
for CED=[1.0:0.01:3.0] model.param.set('C_ED', 'CED[mm]'); model.param.set('C_EP', '1[mm]'); model.param.set('C_EW', '0.5[mm]'); model.param.set('d_ci', '0.5[mm]'); model.param.set('d_nb', '0.4[mm]'); model.sol('sol1').runAll [b1,b2,b3,b4]=graphingfun(model); end
Thanks in advance!
2 Replies Last Post 2019/05/13 6:11 GMT-4
Posted: 7 years ago 2019/05/11 10:51 GMT-4
Hi John,
Why not using an auxiliary sweep?
If the above does not suit you, can you tell us how is the code you submitted not matching your expectations? I am using the java API rather than a LiveLink, so the syntax is slightly different, but from what I can read your code seems fine.
Hi John, Why not using an auxiliary sweep? If the above does not suit you, can you tell us how is the code you submitted not matching your expectations? I am using the java API rather than a LiveLink, so the syntax is slightly different, but from what I can read your code seems fine.
Posted: 7 years ago 2019/05/13 6:11 GMT-4
Hi John
When you do
Then the parameter 'C_ED' is set to the expression 'CED[mm]'. This doesn't transfer the value of the variable CED to Comsol. You need to do this instead:
model.param.set('C_ED', [num2str(CED) '[mm]']);
Lars Gregersen
Comsol Denmark
Hi John When you do model.param.set('C_ED', 'CED[mm]'); Then the parameter 'C_ED' is set to the expression 'CED[mm]'. This doesn't transfer the value of the variable CED to Comsol. You need to do this instead: model.param.set('C_ED', [num2str(CED) '[mm]']);
