2011/11/04 17:44 JST
the induced field is of course calculated and superimposes with the primary field. If you want to see the induced field alone you could try to leave the plate away, or give it zero conductivity and subtract that from the full model.
Cheers
Edgar
Cheers
Edgar
2011/11/04 22:10 JST
Hi, Edgar
Thanks for your reply!
Is it possible to calculate the secondary magnetic field directly from a certain expression? I'd like to display the primary and secondary field at the same time.
Best wishes!
Zheng Wenpei
Hi, Edgar
Best wishes!
Zheng Wenpei
2011/11/04 23:08 JST
Wenpei,
no, I haven't seen that so far. Someone correct me please if I missed it.
Cheers
Edgar
Wenpei,
Cheers
Edgar
2011/11/04 23:42 JST
Edgar,
Someone had told me to Use the first part of Ampère's Law, as shown in the attachment, to build an expression of the secondary field. But I've no idea how to build the expression with the variables of COMSOL. May you could help me.
Best wishes!
Zheng Wenpei
Edgar,
Best wishes!
Zheng Wenpei
2011/11/05 0:25 JST
Wenpei,
I think what he means is to modify the application mode. You would need to modify the underlying differential equation. The term you marked is the only one that depends on the induced current j.
So, this not about postprocessing but rather about modifiying the application mode and its equations. This can of course be done, but I haven't done something like that so far.
Cheers
Edgar
Wenpei,
Cheers
Edgar
2011/11/05 1:16 JST
Edgar,
Thanks a lot! Let me have a try.
By the way, I'd like to get an alternating magnetic field via a multi turn coil with a core in it in 3D mode, how could I build the geometry of the coil, and what kind of current should I choose to add on it?
Best wishes!
Zheng Wenpei
Edgar,
Best wishes!
Zheng Wenpei
2012/06/13 0:23 JST
I'm a begginer but, maybe you can create a new model and study.
In the new model add an "External current density" and put the induced currens solved in the previous problem.
Best wishes
Best wishes
