How to apply solid species transport in Comsol?
When using Transport of Diluted Species in Porous Media (tds), the general equation can be:
where is diffusion and is convection or advection.
Now I want a solid species that works in the sediment itself :
where is biodiffusion/ bioturbation and is sedimentation or burial.
Is it simply making another tds physics where the porosity there is ?
Any other suggestions?
Many thanks,
Yaniv
2 Replies Last Post 2019/06/19 23:30 JST
Posted: 6 years ago 2019/06/18 20:16 JST
Updated: 6 years ago 2019/06/18 20:38 JST
I think I worked a way around the issue:
My way around was to make another Transport of Diluted Species (tds):
where , is the density of the solid and is its molar weight, both are constant. so I am really solving for porosity change in time and depth.
Does anyone know another solution?
Regards
I think I worked a way around the issue: My way around was to make another Transport of Diluted Species (tds): \frac{\partial c_i}{\partial t} -\nabla\cdot(D_i\nabla c_i)+ u\cdot\nabla c_i=R_i where c_i [\frac{mol}{m^3}] = (1-\phi)\frac{\rho_s [\frac{kg}{m^3}]}{M_w [\frac{kg}{mol}]} , \rho_s is the density of the solid and M_w is its molar weight, both are constant. so I am really solving for porosity change in time and depth. Does anyone know another solution? Regards
Posted: 6 years ago 2019/06/19 23:30 JST
Updated: 6 years ago 2019/06/19 23:30 JST
Hi Yaniv,
Why exactly are you not satisfied with your first solution (new tds entry with porosity ). It seems to be the most intuitive way and I don't see a reason to expect any particular problem with it.
Hi Yaniv, Why exactly are you not satisfied with your first solution (new tds entry with porosity 1 - \phi). It seems to be the most intuitive way and I don't see a reason to expect any particular problem with it.
