Hinge model
Hi all,
I've modelled a hinge with structural mechanics module via a rigid connector. Can anyone tell me how I can move (rotate) the connected solid object along the axis of the pin hole?? I've attached the model file and a photo for better understanding.
Many thanks
Shaghayegh
3 Replies Last Post 2019/07/01 23:16 JST
Pawan Soami COMSOL Employee
Posted: 6 years ago 2019/06/21 13:50 JST
Updated: 6 years ago 2019/06/21 13:50 JST
Dear Shaghyegh,
It seems you are using Form union in the geometry whereas for multibody modeling, in order to allow relative motion between the two components, geometry should use Form assembly. Note that before using Form assembly you need to use one or several Union nodes in geometry for domains of each component if they are not already in union state.
You can also refer hinge_assembly model from Application Library for more details.
Best regards, Pawan Soami
Dear Shaghyegh, It seems you are using Form union in the geometry whereas for multibody modeling, in order to allow relative motion between the two components, geometry should use Form assembly. Note that before using Form assembly you need to use one or several Union nodes in geometry for domains of each component if they are not already in union state. You can also refer hinge_assembly model from Application Library for more details. Best regards, Pawan Soami
Posted: 6 years ago 2019/06/21 17:50 JST
Dear Pawan,
Thank you very much for your help.
Kind regards, Shaghayegh
Dear Pawan, Thank you very much for your help. Kind regards, Shaghayegh
Posted: 6 years ago 2019/07/01 23:16 JST
Dear Pawan, I tried using Form assembly and before that I had grouped the domains by using Form union. However, I receieved error. It seems that there is an issue with the way of applying the load and the amount of it. Could you please help me,
Best regards, Shaghayegh
Dear Pawan, I tried using Form assembly and before that I had grouped the domains by using Form union. However, I receieved error. It seems that there is an issue with the way of applying the load and the amount of it. Could you please help me, Best regards, Shaghayegh
